UART Connections!
UART Connections!
qammarabbas
I found a reference schematics of T1042. While connecting UART's pins to the DB9 connector (through driver IC), it uses a series RLC circuit. Can somebody explain its reason?
Please find the attached image for your information. Thank you!
r8070z
The series RLC circuit is a low-pass filter. It cuts radio-frequency noise and decreases electromagnetic interference (EMI).
r8070z
qammarabbas
Thank you!
