Traffic bifurcation using DPDMUX on DPAA2 is not working
713件の閲覧回数
Jeffrey_Lai
Hi NXP,
I try to verify Traffic bifurcation using DPDMUX on DPAA2 function on LX2160 according to the description of LSDK20.04 user guide, section 9.2.11.1.
I use dpmac.3 and dpmac.17 to do the verification but it is not working. I always see dpdmux.0.1 link is down.
The attachment is the procedure log. Please help check the procedure is correct?
Thank you,
Jeffrey
365件の閲覧回数
clarke_liu_f
Have you solved this problem? I have the same problem with LSDK21.08.
