QorIQ Processor DDR Read/Write Margin Test availability
3,405 次查看
partharoy
Hello Support,
Within the QCVS DDR Validation User Guide, I find a statement that read/write margin test feature is not supported in all QorIQ Processor variants.
Can you please tell me in which variants of QorIQ processor, QCVS Read/Write margin test is unavailable?
Thank you.
Pashan
标记 (1)
4 回复数
3,251 次查看
addiyi
You are interested in ARM or PA processors? For ARM based processors only for LS1012A/LS1024/LS102MA the read/write margin tests are not available.
Adrian
3,251 次查看
partharoy
Hello Adrian,
Thank you for the info regarding ARM based QorIQ.
For the PA Processors, read/write margin test are not available in which versions?
Pashan
3,251 次查看
addiyi
For PA you need to install QCVS 4.5 on top of CodeWarrior for PA 10.5.1.
Adrian
3,251 次查看
partharoy
Hello Adrian,
For the
PA processors, which parts doesn't support read/write margin test?
Thank you.
Partha
