P1020 reference clock input
1,691件の閲覧回数
hk1
I'm designing with P1020NXE2HFB. I have a question about reference clock circuit.
I'd like to connect OSC driver output to reference clock input. The signal level is LVDS.
I think the signal can be tied straight and the following components are not necessary.
-dumping resistor
-terminate resistor
-coupling capacitor
Am I correct?
1,678件の閲覧回数
yipingwang
1- the P1020 is not recommended for new designs.
2- in case you need to design with it then please follow the interface guidelines in the attached pdf file application note
