MESA with T1042 ?
MESA with T1042 ?
2,928 次查看
yusufalti333
Hi community,
Is it possible to compile a kernel with MESA for T1042 using Yocto ? If answer is yes, what is the procedure to do this ?
Thanks.
2,857 次查看
yipingwang
Hello Yusuf Altıparmak ,
You could build "mesa" into rootfs, please add "mesa" in sources/meta-freescale/recipes-fsl/images/fsl-image-core.bb as the following.
IMAGE_INSTALL_append = " \
packagegroup-fsl-tools-core \
packagegroup-fsl-benchmark-core \
packagegroup-fsl-networking-core \
glibc-locale \
glibc-utils \
util-linux-agetty \
mesa \
Then regenerate image with the following command.
$ bitbake fsl-image-core
Yiping
2,858 次查看
yipingwang
glibc-locale \
glibc-utils \
util-linux-agetty \
mesa \
Yiping
2,858 次查看
yusufalti333
Hello yipingwang‌,
Does mesa driver support U-boot "video-mode" ?
