LX2160A SDK Question
deepanrajanbara
Hi Team,
Does the SDK have the capability of using the Ethernet interface as a WAN or LAN depending upon the
use case. If this is possible please point me to the document session in which it is described about. As i went through the document Layerscape software development kit user guide. I am not able to understand certain network related descriptions.
Thank you,
Deepanraj.A
Pavel
See the following page:
https://www.opennet.ru/man.shtml?topic=route&category=8&russian=2
NXP Linux BSP supports Ethernet routing.
Pavel Chubakov
deepanrajanbara
Actually what i meant is that daisy chain of the Ethernet port like mentioed in the below link. NXP hardware and software supports it.
The Industrial Ethernet Book | Articles | Technical Articles | Could daisy-chained Ethernet become t...
Pavel
See the following page about difference between LAN and WAN:
https://purple.ai/blogs/whats-the-difference-between-a-lan-and-a-wan/
See the following pages about Linux possibilities for LAN and WAN using:
https://www.nxp.com/docs/en/supporting-information/DN-Digital%20Networking%20solution-2017.pdf
https://askubuntu.com/questions/707672/route-traffic-beetween-lan-wan-interface
https://www.nxp.com/applications/solutions/communication-infrastructure/wireless-networking-infrastr...
https://www.nxp.com/docs/en/data-sheet/QORIW.pdf
Pavel Chubakov
deepanrajanbara
Actually what we required is for the WAN port which will be daissy chained with the LAN port . Is it possible in the NXP chipset LX2160 to daissy chain ethernet port.
