LS1088ARDB QSPI memory layout
1,749 次查看
aabitria
Is there a document showing the memory layout or mapping of files (RCW, u-boot, etc.) for the QSPI device?  WE are using the LS1088ARDB and I think during development we'll need to make changes in those files, but all documents I've seen for the device and board (ref manual, getting started guide) points most info to SD (which we'll not use).
4 回复数
1,472 次查看
aabitria
The LSDK documentation mentions a python script that allows for modifying the RCW as a highlight of 18.03 LSDK.  HOwever I've searched the documentation but there aren't anymore details, on where is it and how to use it for LS1088A.  Is there a clarification for this?
1,472 次查看
ufedor
Please create new Community question or new Technical Case for the last request which is not a direct follow-up for the original one.
1,472 次查看
aabitria
OK Thanks.  At least that narrowed down my search.
1,472 次查看
ufedor
Please refer to the Layerscape Software Development Kit 18.03 Documentation:
Submit Form
