LS1046-TDM
LS1046-TDM
1,429件の閲覧回数
priyankakhangar
Does LS1046 supports TDM interface similar to LS1043? I want to use it for FXS ports using one SLIC IC on TDM interface.
1,320件の閲覧回数
r8070z
The LS1046A does not support TDM interface similar to LS1043A. The LS1043A has QUICC Engine (QE) block with TDM interface. You can find the QorIQ Layerscape Processors with QE on web page
https://www.nxp.com/products/processors-and-microcontrollers/arm-based-processors-and-mcus/qoriq-lay...
