LS1043A, Layout Recommendation
logeshs
We are using LS1043A processor in our Design. I kindly request you to share consolidated layout recommendation for this processor.
Thanks.
Bulat
NXP does not have special layout requirements for the processors. High speed interfaces of each processor typically have special layout requirements. This relates to DDR3, DDR4 and SERDES interfaces. I can recommend following documents for each of mentioned topics:
AN3940 - DDR3 related application note, can be found on the www.nxp.com;
AN5097 - DDR4 related application note, can be found on the www.nxp.com;
http://www.nxp.com/files-static/training_presentation/TP_HARDWARE_DESIGN_PCI_SMGIII.pdf
Bulat
logeshs
Also I request you to share Layout design checklist for this processor (LS1043A), if you have any. we are using 621 ball package processor.
logeshs
Any Update on the Layout Recommendation or Layout Design Checklist?
