Issue with SSL_Connect on QEMU
1,820 次查看
navindaga
I'm using QorIQ Linux SDK v1.6 which has openssl version 1.0.1g. The host OS is CentOS 7.
I run QEMU emulation using qemu-system-ppc64 and I have not been able to establish SSL connection to a server. SSL Connection works from the host system but does not work on QEMU.
Any suggestions?
I use openssl s_client to test connection to the server and on QEMU, it reports :
"error:140790E5:SSL routines:SSL23_WRITE:ssl handshake failure:s23_lib.c:177:"
1,684 次查看
navindaga
Any thoughts anybody?
