IFC GPCM Kernel driver
djz
We have a custom LS1046A board. We want to use IFC to communicate with an on-board FPGA.
Is there a kernel driver for GPCM mode of IFC? So that we can use it from Linux. I only see drivers for NOR/NAND flash.
ufedor
There is no IFC GPCM kernel driver because GPCM chip-select is just a memory bank - i.e. no dedicated driver is needed to perform read/write operations to this area.
In general it is possible to configure the GPCM memory bank in U-Boot.
