How to run the NXP hypervisor by using qemu
2,079件の閲覧回数
nichael99
I built an the NXP hypervisor image according to the code in https://github.com/nxp-qoriq, but when I use the qemu command like "qemu-system-ppc64 -nographic -M ppce500 -cpu e6500 -kernel output/bin/hv", it will hang on, it looks it still need the hypervisor config device tree, guest image, guest device tree.
There is test folder in the hypervisor code, I think that could be used for the guest image, anyway, any simple way to run hypervisor in qemu?
2,061件の閲覧回数
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
Please review Xen Deployment on Layerscape Platforms,
