How to do a SW reset for A72
1,746 次查看
vijaykumardesai
I am using LS1046A[A72] processor, I wanted to do a software reset. Is writing to RMR_EL3 the only way to trigger SW reset.
It is an EL3 register u-boot leaves in EL2, so I can not set this register.
Is there any alternate way to perform the SW reset.
1,583 次查看
Pavel
Look at the Section 4.4.3 of the LS1046A Reference Manual Rev 1:
https://www.nxp.com/webapp/Download?colCode=LS1046ARM
This Section contains command sequence for core soft reset.
Pavel Chubakov
