How to configure and flash the u-boot binary by using Lauterbach trace32 debugger?
2,380 次查看
vinothkumars
Senior Contributor IV
Hi All,
I am working on the Lauterbach trace32 debugger. I have the demo script. I want to configure and flash the u-boot.
But, I don't know the steps. I want the steps to execute and verify.
Thank you for all your support..........!
Regards, VinothS
Vinothkumar Sekar
标记 (3)
2,191 次查看
rweiss
Contributor V
you can set up and perform FLASH programming through the menu:
T42xx - Tools - Program NOR FLASH.
The corresponding FLASH setup script is under
demo\powerpc64bit\hardware\qoriq_t4\all_boards\flash_cfi.cmm
of your TRACE32 installation folder.
For more questions about the debugger, please contact us directly via support@lauterbach.com
Reinhard
4 回复数
2,192 次查看
rweiss
Contributor V
Reinhard
2,190 次查看
vinothkumars
Hi Reinhard,
Thank you for your reply.
Thanks, VinothS
Vinothkumar Sekar
2,191 次查看
alexander_yakov
Sorry, there is no support for Lauterbach Trace32 debugger available from NXP, please contact debugger vendor for support
https://www.lauterbach.com/frames.html?tsupport.html
Alexander
TIC
2,191 次查看
vinothkumars
Hi Alexander,
Thank you for your response.
Regards, VinothS
Vinothkumar Sekar
