Gdb debugger for LS1046
ranga_yn
Hello NXP,
we are using LSDK 19.09  build images for LS1046 . As we can see the Gdb is not working on the board. How to enable the Gdb debugger/ packages to make the Gdb work.
regards,
ranga
Tags (2)
yipingwang
Do you use Ubuntu-based main userland rootfs filesystem?
If so, please run "apt-get install gdb" to install gdb on the target board.
You also could use devel userland rootfs filesystem.
You could add gdb in configs/ubuntu/additional_packages_list in flex-builder build environment.
