From IFC readout Regarding continuous DDR write operation
kojimiura
via IFC
The read value
If you write to DDR continuously,
Will it be pipeline processing?
Expected behavior is
Whether or not the second IFC read is performed while the value read the first time is written to the DDR.
Thank you.
kojimiura
Thank you
yipingwang
It is pipeline processing. The behavior is as the expected.
