DPAA fman micro code questions
veerendranathj
Why micro code uploading is not mandatory for DPAA normal mode but mandatory for independent mode?
Is there any compiler/tool to generate customized DPAA fman micro code?
What exactly DPAA fman micro code contains? What configuration parameters we can control using fman micro code?
ufedor
In normal mode all modules are completely initialized by the DPAA driver, while in the independent mode initialization is preformed by the microcode.
There is no customer-available tool.
There is no customer-available information about the microcode internals.
Please refer to the independent mode description in the processor's DPAARM.
