CPU LS1043A USB interface
2,019 次查看
julien_cavallo
Dear Sir,
I have a question about the USB controller of the LS1043A CPU.
There is a limit (a time out value) in time versus the activation of the USB_DRVVBUS output and the return of the USB PHY VBUS input or not ?
A time limit between the activation of the USB power and the return of the 5V USB vias a USB curent limit component.
Thank in advance for your reply.
Best regards.
1,988 次查看
ufedor
There is no such timeout implemented in software.
1,988 次查看
julien_cavallo
Hi ufedor,
Thank you for your fast reply.
