CCSProtocolPlugin : Error writing registers
4,002件の閲覧回数
D15
When i debug P2010 demo project use CW10.2.1,I am getting "Failed to resume target process., CCSProtocolPlugin : Error writing registers [CCS last error: ELF is in unexpected STOP mode ]".
Is anybody facing same issue?
console output:
Executing Initialization File: D:\PowerPC\Tcl\debug_core_RC240006.tcl
radix x
cmdwin::eclipse::config hexprefix 0x
cmdwin::eclipse::config MemIdentifier v
cmdwin::eclipse::config MemWidth 32
cmdwin::eclipse::config MemAccess 32
cmdwin::eclipse::config MemSwap off
**cmdwin::reg e500 Special Purpose Registers/IVPR = 0xFFFF0000**
**failed on register write: IVPR**
**cmdwin::reg e500 Special Purpose Registers/IVOR15 = 0x0000F000**
**failed on register write: IVOR15**
**cmdwin::reg e500 Special Purpose Registers/IVOR6 = 0x0000F700**
**failed on register write: IVOR6**
**cmdwin::reg e500 Special Purpose Registers/IAC1 = 0xfffffffc**
**failed on register write: IAC1**
**cmdwin::reg e500 Special Purpose Registers/DBCR0 = 0x40800000**
**failed on register write: DBCR0**
**cmdwin::reg e500 Special Purpose Registers/DBCR1 = 0x00000000**
**failed on register write: DBCR1**
**cmdwin::reg Standard Special Purpose Registers/MSR = 0x02000200**
**failed on register write: MSR**
cmdwin::eclipse::config runcontrolsync off
cmdwin::go
cmdwin::wait 50
cmdwin::eclipse::config runcontrolsync on
cmdwin::stop
thread break: Stopped, 0x0, 0x0, cpuPowerPCBig, MPPCASRC240006-core0.elf (state, tid, pid, cpu, target)
**cmdwin::reg e500 Special Purpose Registers/DBCR0 = 0x41000000**
**cmdwin::reg e500 Special Purpose Registers/IAC1 = 0x00000000**
cmdwin::reg e500 Special Purpose Registers/PIR %d -np
cmdwin::mem p:0xff700000 = 0x000e0000
cmdwin::mem p:0xe0005000 = 0x00001000
cmdwin::mem p:0xe0020e44 = 0x0000000C
**cmdwin::reg regPPCTLB1/L2MMU_CAM1 = 0x500003CAFC080000E0000000E0000001**
**failed on register write: L2MMU_CAM1**
**cmdwin::reg regPPCTLB1/L2MMU_CAM2 = 0x70000FCAFC080000FC000000FC000001**
**failed on register write: L2MMU_CAM2**
**cmdwin::reg regPPCTLB1/L2MMU_CAM3 = 0xA0007FCAFC0800008000000080000001**
**failed on register write: L2MMU_CAM3**
**cmdwin::reg regPPCTLB1/L2MMU_CAM6 = 0x400001CAFC080000EFC00000EFC00001**
**failed on register write: L2MMU_CAM6**
**cmdwin::reg regPPCTLB1/L2MMU_CAM7 = 0x400001CAFC080000F8000000F8000001**
**failed on register write: L2MMU_CAM7**
**cmdwin::reg regPPCTLB1/L2MMU_CAM9 = 0x90003FC0FC0800000000000000000001**
**failed on register write: L2MMU_CAM9**
cmdwin::mem p:0xe0000c08 = 0x000fc000
cmdwin::mem p:0xe0000c10 = 0x80400019
cmdwin::mem p:0xe0000c28 = 0x000a0000
cmdwin::mem p:0xe0000c30 = 0x8020001c
cmdwin::mem p:0xe0000c48 = 0x000efc20
cmdwin::mem p:0xe0000c50 = 0x80200010
cmdwin::mem p:0xe0000c68 = 0x00080000
cmdwin::mem p:0xe0000c70 = 0x8000001c
cmdwin::mem p:0xe0000c88 = 0x000efc00
cmdwin::mem p:0xe0000c90 = 0x80000010
cmdwin::mem p:0xe0000ca8 = 0x000f8000
cmdwin::mem p:0xe0000cb0 = 0x80400010
cmdwin::mem p:0xe0000d68 = 0x00000000
cmdwin::mem p:0xe0000d70 = 0x80F0001D
cmdwin::mem p:0xe0002110 = 0x470C0000
cmdwin::mem p:0xe0002000 = 0x0000003F
cmdwin::mem p:0xe0002080 = 0x80014302
cmdwin::mem p:0xe00020c0 = 0x00000000
cmdwin::mem p:0xe0002104 = 0x80320104
cmdwin::mem p:0xe0002108 = 0x6F6B0644
cmdwin::mem p:0xe000210c = 0x0FA89194
cmdwin::mem p:0xe0002100 = 0x00070000
cmdwin::mem p:0xe0002114 = 0x24401010
cmdwin::mem p:0xe0002118 = 0x00061420
cmdwin::mem p:0xe000211c = 0x00000000
cmdwin::mem p:0xe0002120 = 0x00000000
cmdwin::mem p:0xe0002124 = 0x0C30030C
cmdwin::mem p:0xe0002128 = 0xdeadbeef
cmdwin::mem p:0xe0002130 = 0x02800000
cmdwin::mem p:0xe0002160 = 0x00000001
cmdwin::mem p:0xe0002164 = 0x02401400
cmdwin::mem p:0xe0002170 = 0x89080600
cmdwin::mem p:0xe0002174 = 0x8655F607
cmdwin::mem p:0xe0002e48 = 0x00000000
cmdwin::mem p:0xe0002e58 = 0x00000000
cmdwin::mem p:0xe0002b28 = 0x00000000
cmdwin::mem p:0xe0002b2c = 0x00000000
cmdwin::wait 500
cmdwin::mem p:0xe0002110 = 0xC70C0000
cmdwin::wait 500
cmdwin::mem p:0xe0005000 = 0xFC001001
cmdwin::mem p:0xe0005004 = 0xFC000FF7
cmdwin::mem p:0xe0005008 = 0xF8000801
cmdwin::mem p:0xe000500c = 0xFFFE0FF7
**cmdwin::reg e500 Special Purpose Registers/IVPR = 0x00000000**
**cmdwin::reg e500 Special Purpose Registers/IVOR0 = 0x00000100**
**failed on register write: IVOR0**
**cmdwin::reg e500 Special Purpose Registers/IVOR1 = 0x00000200**
**failed on register write: IVOR1**
**cmdwin::reg e500 Special Purpose Registers/IVOR2 = 0x00000300**
**failed on register write: IVOR2**
**cmdwin::reg e500 Special Purpose Registers/IVOR3 = 0x00000400**
**failed on register write: IVOR3**
**cmdwin::reg e500 Special Purpose Registers/IVOR4 = 0x00000500**
**failed on register write: IVOR4**
**cmdwin::reg e500 Special Purpose Registers/IVOR5 = 0x00000600**
**failed on register write: IVOR5**
**cmdwin::reg e500 Special Purpose Registers/IVOR6 = 0x00000700**
**cmdwin::reg e500 Special Purpose Registers/IVOR8 = 0x00000c00**
**failed on register write: IVOR8**
**cmdwin::reg e500 Special Purpose Registers/IVOR10 = 0x00000900**
**failed on register write: IVOR10**
**cmdwin::reg e500 Special Purpose Registers/IVOR11 = 0x00000f00**
**failed on register write: IVOR11**
**cmdwin::reg e500 Special Purpose Registers/IVOR12 = 0x00000b00**
**failed on register write: IVOR12**
**cmdwin::reg e500 Special Purpose Registers/IVOR13 = 0x00001100**
**failed on register write: IVOR13**
**cmdwin::reg e500 Special Purpose Registers/IVOR14 = 0x00001000**
**failed on register write: IVOR14**
Please help me to resolve this issue.
Thanks & Regards,
6 返答(返信)
3,924件の閲覧回数
D15
core 0 not ready,what can be the reason?
3,921件の閲覧回数
yipingwang
Would you please refer to the following procedure to capture CCS log in CodeWarrior IDE to me to do more investigation?
Before connect to the target, please enable CCS log from
"Run->Debug Configurations-><project>-core00_RAM_P2010_Download->Edit...->Advanced->Advanced CCS setting->Enable logging", and connect to the target from "Run->Debug Configurations-><project>-core00_RAM_p2010_Download->Debug”, the CCS log will be printed in the console panel in CodeWarrior IDE.
Note: Please open the console panel from Window->Show View->Console, and if nothing displayed, please choose the correct session on the right top icon in the panel. If the CCS log in the console is truncated, please enlarge the console buffer from Window->Preferences->Run/Debug->Console->uncheck "Limit console output".
3,918件の閲覧回数
D15
AREADY during POR is low,and core 0 is not ready,what can be the reason?
3,851件の閲覧回数
yipingwang
Please refer to page 5 for JTAG interface hardware configuration.
3,915件の閲覧回数
D15
log info:
ccs_open
    ipaddr = 127.0.0.1
    port = 41475
    timeout = 15
    serverh = 0
    ccs_open; ccs_error = 10
    Error message: Connection refused
ccs_open
    ipaddr = 127.0.0.1
    port = 41475
    timeout = 15
    serverh = 0
    ccs_open; ccs_error = 0
ccs_get_connection_count
    serverh = 0
    count = 1
    ccs_get_connection_count; ccs_error = 0
ccs_available_connections
    serverh = 0
    count = 0
    ccs_available_connections; ccs_error = 0
    serverh = 0
    count = 0
ccs_config_cc
    serverh = 0
    config_string = utap:0
    ccs_config_cc; ccs_error = 0
    serverh = 0
    count = 1
    serverh = 0
    count = 1
ccs_cc_version
    serverh = 0
    cc = 0
    version.major = 0
    version.minor = 0
    ccs_cc_version; ccs_error = 0
ccs_set_timeout
    serverh = 0
    timeout = 15
    ccs_set_timeout; ccs_error = 0
ccs_config_server
    serverh = 0
    cc = 0
    server_config = 0
    value = 10256
    ccs_config_server; ccs_error = 0
ccs_get_server_config
    serverh = 0
    cc = 0
    server_config = 1
    value = 0
    ccs_get_server_config; ccs_error = 0
ccs_config_server
    serverh = 0
    cc = 0
    server_config = 1
    value = 256
ccs_config_chain
    serverh = 0
    cc = 0
    device_list: (size = 1)
        device[0]:: core_type=test core(20)
    ccs_config_chain; ccs_error = 0
ccs_jtag_lock
    serverh = 0
    cc = 0
    ccs_jtag_lock; ccs_error = 0
ccs_jtag_state_move
    serverh = 0
    cc = 0
    state = 0
    ccs_jtag_state_move; ccs_error = 0
ccs_jtag_scan_io
    serverh = 0
    cc = 0
    reg = 1
    bit_length = 2048
    odata: (size = 256)
         00000000 00000000 00000000 00000000
    state = 0
    idata: (size = 256)
         1D300E00 00000000 00000000 00000000
    ccs_jtag_scan_io; ccs_error = 0
ccs_jtag_unlock
    serverh = 0
    cc = 0
    ccs_jtag_unlock; ccs_error = 0
JTAG Diagnostics OK
Detected JTAG IDCODEs:
TDO ----
          * Device 0 IDCODE: 000E301D
TDI ----
ccs_config_server
    serverh = 0
    cc = 0
    server_config = 1
    value = 0
ccs_config_chain
    serverh = 0
    cc = 0
        device[0]:: core_type=Draco/m HIP8(53)
ccs_config_template
    coreh = [serverh:0;cc_index:0;chain_pos:0]
    config_reg = -2147483648
    config_data = 1
    ccs_config_template; ccs_error = 0
ccs_get_config_chain
    serverh = 0
    ccs_get_config_chain; ccs_error = 0
    serverh = 0
ccs_send_message
    message = 3
    ccs_send_message; ccs_error = 0
Executing Initialization File: D:\PowerPC\01_Workspace\P2010-core0\CFG\init_sram_flash.tcl
radix x
cmdwin::mem p:0xff700000 = 0x000ffe00
ccs_stop_core
    ccs_stop_core; ccs_error = -2147483635
    Error message: ELF is not in expected HALT mode
ccs_write_mem
    addr = [space:0;size:4;address:0xff700000]
    data: (size = 4)
         000FFE00
    ccs_write_mem; ccs_error = 0; duration=4 ms
cmdwin::mem p:0xffe20e44 = 0x0000000C
ccs_stop_core
ccs_write_mem
    addr = [space:0;size:4;address:0xffe20e44]
    data: (size = 4)
         0000000C
    ccs_write_mem; ccs_error = 0; duration=1 ms
ccs_stop_core
ccs_write_register
    index = 2034
    count = 1
    size = 4
    value: (size = 4)
         02000200
    ccs_write_register; ccs_error = -2147483634; duration=4 ms
cmdwin::reg regPPCTLB1/L2MMU_CAM1 = 0x500003CAFC080000FFE00000FFE00001
ccs_stop_core
ccs_out
    ccs_io addr: (size = 4)
         0x00000000 0x20000989 0x00000000 0x00000000
    value: (size = 12)
         FFE00000 1FC3FF80 3F140A80
    ccs_out; ccs_error = -2147483634; duration=3 ms
cmdwin::reg regPPCTLB1/L2MMU_CAM3 = 0x400001C0FC0800000000000000000001
ccs_stop_core
ccs_out
         0x00000000 0x2000098b 0x00000000 0x00000000
    value: (size = 12)
         00000000 0FC00000 3F000880
cmdwin::mem p:0xffe00020 = 0x00000000
ccs_stop_core
ccs_write_mem
    addr = [space:0;size:4;address:0xffe00020]
    data: (size = 4)
         00000000
    ccs_write_mem; ccs_error = 0; duration=2 ms
cmdwin::mem p:0xffe20000 = 0x60020000
ccs_stop_core
    ccs_stop_core; ccs_error = -2147483633
    Error message: ELF is in unexpected STOP mode
ccs_write_mem
    addr = [space:0;size:4;address:0xffe20000]
    data: (size = 4)
         60020000
cmdwin::mem p:0xffe20100 = 0x00000000
ccs_stop_core
ccs_write_mem
    addr = [space:0;size:4;address:0xffe20100]
    data: (size = 4)
         00000000
cmdwin::mem p:0xffe20104 = 0x00000000
ccs_stop_core
ccs_write_mem
    addr = [space:0;size:4;address:0xffe20104]
    data: (size = 4)
         00000000
cmdwin::mem p:0xffe20000 = 0xA0020000
ccs_stop_core
ccs_write_mem
    data: (size = 4)
         A0020000
cmdwin::mem p:0xffe07000 = 0x80000403
ccs_stop_core
ccs_write_mem
    addr = [space:0;size:4;address:0xffe07000]
    data: (size = 4)
         80000403
cmdwin::mem p:0xffe07008 = 0x0000FB00
ccs_stop_core
ccs_write_mem
    addr = [space:0;size:4;address:0xffe07008]
    data: (size = 4)
         0000FB00
cmdwin::mem p:0xffe07020 = 0x28170008
ccs_stop_core
ccs_write_mem
    addr = [space:0;size:4;address:0xffe07020]
    data: (size = 4)
         28170008
ccs_stop_core
ccs_write_register
    index = 63
    count = 1
    size = 4
    value: (size = 4)
         00000000
    ccs_write_register; ccs_error = -2147483633; duration=1 ms
ccs_stop_core
ccs_read_register
    index = 2032
    count = 1
    size = 4
    value: (size = 4)
         ECE9C903
    ccs_read_register; ccs_error = -2147483633; duration=2 ms
ccs_stop_core
ccs_write_register
    index = 400
    count = 1
    size = 4
    value: (size = 4)
         00000100
    ccs_write_register; ccs_error = -2147483633; duration=2 ms
ccs_stop_core
ccs_write_register
    index = 401
    count = 1
    size = 4
    value: (size = 4)
         00000200
ccs_stop_core
ccs_write_register
    index = 402
    count = 1
    size = 4
    value: (size = 4)
         00000300
ccs_read_reg
    index = 63
    count = 1
    value: (size = 1)
         0xd0f2be00
    ccs_read_reg; ccs_error = -2147483633; duration=2 ms
ccs_config_template
    config_reg = 65536
    config_data = 207528448
ccs_read_mem
    addr = [space:0;size:4;address:0x00000000]
    data: (size = 256)
    ccs_read_mem; ccs_error = 0; duration=6 ms
ccs_read_register
    index = 285212672
    count = 1
    size = 4
    value: (size = 4)
         00000003
    ccs_read_register; ccs_error = 0; duration=3 ms
ccs_read_register
    index = 285212672
    count = 1
    size = 4
    value: (size = 4)
         00000003
ccs_read_register
    index = 285212673
    count = 1
    size = 4
    value: (size = 4)
         00000001
    ccs_read_register; ccs_error = 0; duration=2 ms
ccs_read_register
    index = 285212693
    count = 1
    size = 4
    value: (size = 4)
         00000002
ccs_read_register
    index = 285212713
    count = 1
    size = 4
    value: (size = 4)
         00000003
ccs_in
         0x00000000 0x00002710 0x00000000 0x00000000
    value: (size =
         08DC1700 20E81900
    ccs_in; ccs_error = -2147483633; duration=2 ms
ccs_in
         0x00000000 0x00002711 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002712 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002713 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002714 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002715 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002716 0x00000000 0x00000000
    value: (size =
         64650000 00000000
    ccs_in; ccs_error = -2147483633; duration=1 ms
ccs_in
         0x00000000 0x00002717 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002718 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002719 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x0000271a 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x0000271b 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x0000271c 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x0000271d 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x0000271e 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x0000271f 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002720 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002721 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002722 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002723 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002724 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002725 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002726 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002727 0x00000000 0x00000000
    value: (size =
         64650000 00000000
    ccs_in; ccs_error = -2147483633; duration=3 ms
ccs_in
         0x00000000 0x00002728 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x00002729 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x0000272a 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x0000272b 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x0000272c 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x0000272d 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x0000272e 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_in
         0x00000000 0x0000272f 0x00000000 0x00000000
    value: (size =
         64650000 00000000
ccs_read_register
    index = 2032
    count = 2
    size = 4
    value: (size =
         00000000 00006564
ccs_read_register
    index = 8
    count = 2
    size = 4
    value: (size =
         00000000 00006564
ccs_read_register
    index = 1
    count = 1
    size = 4
    value: (size = 4)
         00000000
ccs_config_template
    config_reg = 65536
    config_data = 0
ccs_read_mem
    addr = [space:0;size:4;address:0x00000100]
    data: (size = 256)
         9421FFB0 90010008 7C0902A6 9001000C
         7C0102A6 90010010 7C000026 90010014
         7C0802A6 90010018 90610028 9081002C
         90A10030 90C10034 90E10038 9101003C
         91210040 91410044 91610048 9181004C
         7C1A0AA6 9001001C 7C1B0AA6 90010020
         38600100 7C9042A6 7C8803A6 4E800021
         80010020 7C1B0BA6 8001001C 7C1A0BA6
         80610028 8081002C 80A10030 80C10034
         80E10038 8101003C 81210040 81410044
         81610048 8181004C 80010018 7C0803A6
         80010014 7C0FF120 80010010 7C0103A6
         8001000C 7C0903A6 80010008 38210050
         4C000066 00000000 00000000 00000000
    ccs_read_mem; ccs_error = 0; duration=5 ms
ccs_read_reg
    index = 308
    count = 1
    value: (size = 1)
         0x00000000
thread break: Stopped, 0x0, 0x0, cpuPowerPCBig, P2010-core0.elf (state, tid, pid, cpu, target)
ccs_write_register
    index = 403
    count = 1
    size = 4
    value: (size = 4)
         00000400
ccs_write_register
    index = 404
    count = 1
    size = 4
    value: (size = 4)
         00000500
ccs_write_register
    index = 405
    count = 1
    size = 4
    value: (size = 4)
         00000600
ccs_write_register
    index = 406
    count = 1
    size = 4
    value: (size = 4)
         00000700
ccs_write_register
    index = 408
    count = 1
    size = 4
    value: (size = 4)
         00000C00
ccs_write_register
    index = 410
    count = 1
    size = 4
    value: (size = 4)
         00000900
ccs_write_register
    index = 411
    count = 1
    size = 4
    value: (size = 4)
         00000F00
    ccs_write_register; ccs_error = -2147483633; duration=3 ms
ccs_write_register
    index = 412
    count = 1
    size = 4
    value: (size = 4)
         00000B00
ccs_write_register
    index = 413
    count = 1
    size = 4
    value: (size = 4)
         00001100
ccs_write_register
    index = 414
    count = 1
    size = 4
    value: (size = 4)
         00001000
cmdwin::reg e500 Special Purpose Registers/IVOR15 = 0x00001500
ccs_write_register
    index = 415
    count = 1
    size = 4
    value: (size = 4)
         00001500
cmdwin::reg e500 Special Purpose Registers/IVOR32 = 0x00001600
ccs_write_register
    index = 528
    count = 1
    size = 4
    value: (size = 4)
         00001600
failed on register write: IVOR32
cmdwin::reg e500 Special Purpose Registers/IVOR33 = 0x00001700
ccs_write_register
    index = 529
    count = 1
    size = 4
    value: (size = 4)
         00001700
failed on register write: IVOR33
cmdwin::reg e500 Special Purpose Registers/IVOR34 = 0x00001800
ccs_write_register
    index = 530
    count = 1
    size = 4
    value: (size = 4)
         00001800
failed on register write: IVOR34
3,965件の閲覧回数
D15
anyone occur this problem?
