Action erase flash on T1040 board loop forever ?
tienphamxuan
Hello, I meet a problem with T1040 flash programing. When i erase flash on T1040 board the erasing task running forever :
fl::target -lc "T1040-core00_SRAM_T1040_Download"
fl::target -b 0x0 0x40000
fl::target -v off -l off
cmdwin::fl::device -d "S29GL256P" -o "16Mx16x1" -a 0xe8000000 0xe9ffffff
cmdwin::fl::protect all off
 Beginning Operation ...
Performing target initialization ...
 Downloading Flash Diagnostics Driver ...
 Reading flash ID ...
Unprotecting all sectors...
Unprotecting ...
Unprotecting ....
Unprotecting .....
Unprotecting ......
 Unprotect Command Succeeded
cmdwin::fl::device -sd all
cmdwin::fl::device -se 0
cmdwin::fl::erase list
 Downloading Flash Device Driver ...
Erasing Sector 0xE8000000 to 0xE801FFFF
 Erasing .............................................................
Erasing ..
Erasing ..
Erasing ..
Anyone can help me ?
tienphamxuan
Hi all, thanks for reviewed. I solved this problem by myself. I disable BTCL signal on NOR IFC bus.
