Booting from QSPI on LS102xA
LS1021xA series product starts to support QSPI flash booting.
But booting from QSPI flash isn't the same as booting from SPI flash.
QSPI booting use XIP(Execute in place) method just like NOR Flash booting.
The memory map start address assigned to QSPI flash is 0x4000000.
You need to put your code at the right location.
And another key point you should be noted is data endian format between QSPI controller and ARM AMBA AXI bus.2.gif
Any binary file burned into QSPI Flash should be done Byte-Swap process first.
Our Ls1021xA Bsp has provided this function at Tcl script file named “byte_swap.tcl”.
Follow the below command to finish this process .
tclsh ./byte_swap.tcl ./<original file name>.bin ./<Byte-swap file name>.bin 8
Then Boot up system from SD/MMC media.
Burn the image file into QSPI Flash by following commands.
=>tftp 0x81000000 rcw_qspiboot_swap.bin
(Measure this binary file contains PBI command: 0xee0200, 0x40010000
This is  the Workaround for u-boot address )
=> sf probe
=> sf erase 0 0x10000
=> sf write 0x81000000 0 0x100
=> tftp 0x82000000 u-boot-qspiboot_swap.bin
=> sf erase 0x10000 0x90000
=> sf write 0x82000000 0x10000 0x80000
评论
I'm working on booting a customized LS1021A board from QSPI flash and I have one question:
What's the file rcw_qspiboot_swap.bin?
While I compile the u-boot, I can only get the u-boot.bin.
Is that file necessary to boot up a board?
You may use script "byte_swap.tcl" to swap your rcw.bin to rcw_qspiboot_swap.bin.
you could use QorIQ Configuration suite"pre-boot loader tool" to generate specific RCW binary file for your customized board.
Yes,it is a pre-boot loader code and you need to modify it carefully.
Thanks Ming-Che,
Is the RCW binary file always needed no matter how I boot my LS1021A board?
Are those configurations already included in u-boot like imx6?
Yes, RCW binary file is necessary for T series ,LS series and part of P series QorIQ product.
Our SDK will help you insert RCW Data into U-boot binary file automatically after code-build process.
But LS SDK hasn't completed all feature yet.
%3CLINGO-SUB%20id%3D%22lingo-sub-1099418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BB%8E%20LS102xA%20%E4%B8%8A%E7%9A%84%20QSPI%20%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ELS1021xA%E7%B3%BB%E5%88%97%E4%BA%A7%E5%93%81%E5%BC%80%E5%A7%8B%E6%94%AF%E6%8C%81QSPI%E9%97%AA%E5%AD%98%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E4%BB%8E%20QSPI%20%E9%97%AA%E5%AD%98%E5%90%AF%E5%8A%A8%E4%B8%8E%E4%BB%8E%20SPI%20%E9%97%AA%E5%AD%98%E5%90%AF%E5%8A%A8%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%3EQSPI%20%E5%90%AF%E5%8A%A8%E4%BD%BF%E7%94%A8%20XIP%EF%BC%88%E5%B0%B1%E5%9C%B0%E6%89%A7%E8%A1%8C%EF%BC%89%E6%96%B9%E6%B3%95%EF%BC%8C%E5%B0%B1%E5%83%8F%20NOR%20Flash%20%E5%90%AF%E5%8A%A8%E4%B8%80%E6%A0%B7%E3%80%82%3C%2FP%3E%3CP%3E%E5%88%86%E9%85%8D%E7%BB%99%20QSPI%20%E9%97%AA%E5%AD%98%E7%9A%84%E5%86%85%E5%AD%98%E6%98%A0%E5%B0%84%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%E4%B8%BA%200x4000000%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E9%9C%80%E8%A6%81%E5%B0%86%E4%BB%A3%E7%A0%81%E6%94%BE%E5%9C%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-size%3A%2012pt%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.gif%22%20style%3D%22width%3A%20900px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F43535iF2C9732027C57D17%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.gif%22%20alt%3D%221.gif%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-size%3A%2012pt%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E6%82%A8%E5%BA%94%E8%AF%A5%E6%B3%A8%E6%84%8F%E7%9A%84%E5%8F%A6%E4%B8%80%E4%B8%AA%E5%85%B3%E9%94%AE%E7%82%B9%E6%98%AF%20QSPI%20%E6%8E%A7%E5%88%B6%E5%99%A8%E5%92%8C%20ARM%20AMBA%20AXI%20%E6%80%BB%E7%BA%BF%E4%B9%8B%E9%97%B4%E7%9A%84%E6%95%B0%E6%8D%AE%E5%AD%97%E8%8A%82%E5%BA%8F%E6%A0%BC%E5%BC%8F%E3%80%82%3C%2FSPAN%3E%3CEM%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.gif%22%20style%3D%22width%3A%20704px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F43586i411332BE8AFB80E2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.gif%22%20alt%3D%222.gif%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BB%BB%E4%BD%95%E5%88%BB%E5%BD%95%E5%88%B0%20QSPI%20Flash%20%E7%9A%84%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E9%83%BD%E5%BA%94%E9%A6%96%E5%85%88%E5%AE%8C%E6%88%90%E5%AD%97%E8%8A%82%E4%BA%A4%E6%8D%A2%E8%BF%87%E7%A8%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E7%9A%84%20Ls1021xA%20Bsp%20%E5%9C%A8%E5%90%8D%E4%B8%BA%E2%80%9Cbyte_swap.tcl%E2%80%9D%E7%9A%84%20Tcl%20%E8%84%9A%E6%9C%AC%E6%96%87%E4%BB%B6%E4%B8%AD%E6%8F%90%E4%BE%9B%E4%BA%86%E6%AD%A4%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FP%3E%3CP%3E%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%AE%8C%E6%88%90%E6%AD%A4%E8%BF%87%E7%A8%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3Etclsh%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%20.%2Fbyte_swap.tcl%20.%2F%3CORIGINAL%20file%3D%22%22%20name%3D%22%22%3E.bin%20.%2F%3CBYTE-SWAP%20file%3D%22%22%20name%3D%22%22%3E.bin%208%3C%2FBYTE-SWAP%3E%3C%2FORIGINAL%3E%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%E7%84%B6%E5%90%8E%E4%BB%8E%20SD%2FMMC%20%E5%AA%92%E4%BD%93%E5%90%AF%E5%8A%A8%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%B0%86%E6%98%A0%E5%83%8F%E6%96%87%E4%BB%B6%E5%88%BB%E5%BD%95%E5%88%B0%20QSPI%20Flash%20%E4%B8%AD%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3E%3D%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3Etftp%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E0x81000000%20rcw_qspiboot_swap.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%233366ff%3B%22%3E%EF%BC%88%E6%B5%8B%E9%87%8F%E6%AD%A4%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%8C%85%E5%90%ABPBI%E5%91%BD%E4%BB%A4%EF%BC%9A0xee0200%E3%80%810x40010000%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%233366ff%3B%22%3E%E8%BF%99%E6%98%AF%20u-boot%20%E5%9C%B0%E5%9D%80%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%3D%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3ESF%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%E6%8E%A2%E6%B5%8B%E5%99%A8%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%3D%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3Esf%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%E6%93%A6%E9%99%A4%200%200x10000%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%3D%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3Esf%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%E5%86%99%E5%85%A5%200x81000000%200%200x100%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%3D%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3Etftp%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%200x82000000%20u-boot-qspiboot_swap.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%3D%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3Esf%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%E6%93%A6%E9%99%A4%200x10000%200x90000%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%3D%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3Esf%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%E5%86%99%E5%85%A5%200x82000000%200x10000%200x80000%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BB%8E%20LS102xA%20%E4%B8%8A%E7%9A%84%20QSPI%20%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8CT%E7%B3%BB%E5%88%97%E3%80%81LS%E7%B3%BB%E5%88%97%E5%92%8C%E9%83%A8%E5%88%86P%E7%B3%BB%E5%88%97QorIQ%E4%BA%A7%E5%93%81%E9%9C%80%E8%A6%81RCW%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E7%9A%84%20SDK%20%E5%B0%86%E5%B8%AE%E5%8A%A9%E6%82%A8%E5%9C%A8%E4%BB%A3%E7%A0%81%E6%9E%84%E5%BB%BA%E8%BF%87%E7%A8%8B%E4%B9%8B%E5%90%8E%E8%87%AA%E5%8A%A8%E5%B0%86%20RCW%20%E6%95%B0%E6%8D%AE%E6%8F%92%E5%85%A5%20U-boot%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86LS%20SDK%E5%B0%9A%E6%9C%AA%E5%AE%8C%E6%88%90%E6%89%80%E6%9C%89%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BB%8E%20LS102xA%20%E4%B8%8A%E7%9A%84%20QSPI%20%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22n%20fn%22%3E%E8%B0%A2%E8%B0%A2%E6%98%8E%E5%93%B2%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22n%20fn%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22n%20fn%22%3E%3CSPAN%20class%3D%22n%20fn%22%3E%E6%97%A0%E8%AE%BA%E6%88%91%E5%A6%82%E4%BD%95%E5%90%AF%E5%8A%A8%20LS1021A%20%E6%9D%BF%EF%BC%8C%3C%2FSPAN%3E%E6%98%AF%E5%90%A6%E6%80%BB%E6%98%AF%E9%9C%80%E8%A6%81%20RCW%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22n%20fn%22%3E%E8%BF%99%E4%BA%9B%E9%85%8D%E7%BD%AE%E6%98%AF%E5%90%A6%E5%B7%B2%E7%BB%8F%E5%83%8F%20imx6%20%E4%B8%80%E6%A0%B7%E5%8C%85%E5%90%AB%E5%9C%A8%20u-boot%20%E4%B8%AD%EF%BC%9F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BB%8E%20LS102xA%20%E4%B8%8A%E7%9A%84%20QSPI%20%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3Ercw_qspiboot_swap.bin%20%E6%96%87%E4%BB%B6%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%20style%3D%22%3A%20%3B%20color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3E%E8%84%9A%E6%9C%AC%E2%80%9C%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%20style%3D%22%3A%20%3B%20color%3A%20%23575757%3B%20font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%20style%3D%22%3A%20%3B%20color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3Ebyte_swap.tcl%E2%80%9D%E5%B0%86%20rcw.bin%20%E4%BA%A4%E6%8D%A2%E4%B8%BA%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3Ercw_qspiboot_swap.bin%E3%80%82%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3Etclsh%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%20.%2Fbyte_swap.tcl%20.%2F%3CORIGINAL%20file%3D%22%22%20name%3D%22%22%3E.bin%20.%2F%3CBYTE-SWAP%20file%3D%22%22%20name%3D%22%22%3E.bin%208%3C%2FBYTE-SWAP%3E%3C%2FORIGINAL%3E%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%BD%93%E6%88%91%E7%BC%96%E8%AF%91%20u-boot%20%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AA%E8%83%BD%E5%BE%97%E5%88%B0%20u-boot.bin%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20QorIQ%20%E9%85%8D%E7%BD%AE%E5%A5%97%E4%BB%B6%E2%80%9C%E9%A2%84%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%B7%A5%E5%85%B7%E2%80%9D%E4%B8%BA%E6%82%A8%E7%9A%84%E5%AE%9A%E5%88%B6%E6%9D%BF%E7%94%9F%E6%88%90%E7%89%B9%E5%AE%9A%E7%9A%84%20RCW%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%AF%A5%E6%96%87%E4%BB%B6%E5%AF%B9%E4%BA%8E%E5%90%AF%E5%8A%A8%E4%B8%BB%E6%9D%BF%E6%98%AF%E5%90%A6%E5%BF%85%E8%A6%81%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E9%A2%84%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E5%B0%8F%E5%BF%83%E4%BF%AE%E6%94%B9%E5%AE%83%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BB%8E%20LS102xA%20%E4%B8%8A%E7%9A%84%20QSPI%20%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BB%8E%20QSPI%20%E9%97%AA%E5%AD%98%E5%90%AF%E5%8A%A8%E5%AE%9A%E5%88%B6%E7%9A%84%20LS1021A%20%E6%9D%BF%EF%BC%8C%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3Ercw_qspiboot_swap.bin%20%E6%96%87%E4%BB%B6%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E7%BC%96%E8%AF%91%20u-boot%20%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AA%E8%83%BD%E5%BE%97%E5%88%B0%20u-boot.bin%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%A5%E6%96%87%E4%BB%B6%E5%AF%B9%E4%BA%8E%E5%90%AF%E5%8A%A8%E4%B8%BB%E6%9D%BF%E6%98%AF%E5%90%A6%E5%BF%85%E8%A6%81%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎08-24-2014 10:52 PM
更新人:
