how to generate a code using PE for the new version ???
vikassubramani
I am using MC9S08DN16 controller and want ADC code hwo can i generate the code using PE ??
Petr_H
you might also want to take a look at
How to quickly start using Processor Expert in CodeWarrior?
and
Where can I find Processor Expert examples and tutorials in CodeWarrior?
Petr Hradsky
Processor Expert Support Team
ZhangJennie
hi vikas,
i suppose you use CW10.6.
under CW10.6 install {CW10.6 install}\MCU\Help\PDF, there is ProcessorExpertHelp.pdf which documents how to using pe
and there is also pe sample code under  {CW10.6 install}\MCU\CodeWarrior_Examples\Processor_Expert
this answer is for you, if it helps, please click on "correct answer" button.
ZhangJun
