how does NFC_LDD map pages to blocks/pages?
1,118件の閲覧回数
bowerymarc
The WritePages and ReadPages API in NFC_LDD only asks for page number, and not block number.  But erase blocks wants blocks.  I need to know the mapping of pages to blocks for this to work, otherwise how can I know which page to erase and then write?
Is is simply blockNumber x NAND_FLASH_PAGE_SIZE + pageNumber?
or blockNumber x NAND_FLASH_PHY_PAGE_SIZE + pageNumber?
thanks,
Marc
タグ(3)
965件の閲覧回数
vfilip
please check the details from our development team below. Anyway we will improve the documentation or will add some #define for next release:
These symbols are defined in NFC componenets header file:
#define NAND_FLASH_PAGE_COUNT                0xYYU
#define NAND_FLASH_BLOCK_COUNT               0xYYU
You can define new symbol  NAND_FLASH_BLOCK_PAGE_COUNT
#define  NAND_FLASH_BLOCK_PAGE_COUNT        (NAND_FLASH_PAGE_COUNT  / NAND_FLASH_BLOCK_COUNT )
and use folowing macro for page address to block address mapping:
#define GetBlockAddressFromPageAddress(_PageAddress_)     (_PageAddress_  /  NAND_FLASH_BLOCK_PAGE_COUNT)
Vojtech Filip
Processor Expert Support Team
966件の閲覧回数
vfilip
Vojtech Filip
