fsl_sdioslv
fsl_sdioslv
leewei0618
Some macros in the fsl_sdioslv.c/fsl_sdioslv.h file are not defined, such as: SDIOSLV_GLB_INT_EN_REG_FN0_INT_TO_ARM_EN_MASK/SDIOSLV_FNO_INT_EN_AHBSOFT_RST_EN_MASK, etc.
EdwinHz
Hi @leewei0618,
Could you please share what NXP device are you using, so we can provide you with better support?
leewei0618
NXP MCX Microcontrollers (MCUs), i clone code from github repo, mcxsdk-core and mcuxsdk-examples;
https://github.com/nxp-mcuxpresso/mcuxsdk-examples
https://github.com/nxp-mcuxpresso/mcuxsdk-core
EdwinHz
Hi @leewei0618,
Thanks for clarifying.
I will share this finding with the SDK so they can deliberate on how to modify the driver.
For now, please use the direct register address to modify the register rather than these missing mask definitions.
leewei0618
Got it — thanks for the heads-up and for passing the info on to the SDK team.
We’ll switch to using the raw register addresses for now and keep the code on ice until the mask definitions are officially added. Let me know if there’s anything else you need from our side to help the driver folks move forward.
