ethernet eth0 problem
1,185件の閲覧回数
mallikarjuntera
Hello ,
we are using nitrogen6x_max board where the Ethernet eth0 is not working, it is failing at boot time.
and getting error:
ifconfig :SIOCIFFLAGS: no such device
even if we try to make ethernet eth0 up with ifconfig ,getting the same error:
Here is the dmesg | grep eth
[    1.825482] 2188000.ethernet supply phy not found, using dummy regulator
[    1.830803] fec 2188000.ethernet eth0: registered PHC device 0
can any one tell what might be gone wrong ? whether there is problm with driver or PHY chipset device is not able to find by fec driver.
0 返答(返信)
