System Oscillator Enabled isn't Reflected in MCG Settings
2,417 次查看
chiasyan
I am having trouble to set the MCG mode to PEE due to the issue mentioned. Is it a bug or I am doing it wrong?
Thank you.
标记 (5)
2,314 次查看
chiasyan
Close and re-open the project solved the issue.
2,315 次查看
chiasyan
2,314 次查看
Monica
Senior Contributor III
That's great Chiasyan!
Would you mind sharing how you solved it out?
Monica
