System Oscillator Enabled isn't Reflected in MCG Settings
chiasyan
I am having trouble to set the MCG mode to PEE due to the issue mentioned. Is it a bug or I am doing it wrong?
Thank you.
Tags (5)
chiasyan
Close and re-open the project solved the issue.
chiasyan
Monica
Senior Contributor III
That's great Chiasyan!
Would you mind sharing how you solved it out?
Monica
