I'm trying to enable pin sharing in KDS v3.0.0 with associated PE version 3.0.1. My target device is MK22FN512. I was able to get this working with KDS v2.0.0 and its associated Processor Expert, but it doesn't seem to work in KDS3.
PEx_for_Kinetis_User_Manual.pdf has section 3.3.8 on pin sharing. There is no Expert mode any more, so the documentation is not up to date. I'm unable to see the pop-up Pin Sharing menu option under a peripheral pin.
Is this still possible with PE 3.0.1? I try setting ConnectPin Method to "generate code" and it doesn't help.
Michael Goudey
