Set ram size from SPL.
4,340件の閲覧回数
Arm7
Could you help me, Where in the SPL ( Secondary program Loader ) can I set the ram size?
Currently, the configuration is done in u-boot like: gd->ram_size = PHYS_SDRAM_SIZE;
And now, I have to do it in the SPL side.
I'd appreciate the support. Thank you!
タグ(1)
4,253件の閲覧回数
Zhiming_Liu
Hello @Arm7
The SPL is not designed to set global data
5 返答(返信)
4,296件の閲覧回数
Zhiming_Liu
Hi @Arm7
There is no example code for setting ram size in SPL.
4,277件の閲覧回数
Arm7
Hello @Zhiming_Liu,
Thank you for the support, CONFIG_SPL_SIZE_LIMIT it seems, this configuration is only for SPL side, When the boot sequence ends, in kernel, the configuration would be kept ?
4,254件の閲覧回数
Zhiming_Liu
Hello @Arm7
4,227件の閲覧回数
Arm7
Hello @Zhiming_Liu
Could you give me a little more detail please?
Is this documented somewhere ?
Thank you!
4,203件の閲覧回数
Zhiming_Liu
