RT1050 USB Example
RT1050 USB Example
3,731件の閲覧回数
ahmedtolba
I have a MCU that streams data over USB2 ( the data is video data) I would like to know an example that takes that stream from RT1050 and display it over LCD. The stream is not encoded by any encoder it's pure RGB Data.
タグ(1)
5 返答(返信)
3,705件の閲覧回数
ahmedtolba
Is it possible to receive MJEP video stream ? not sending it ? is there an example of decoding that stream and receiving it using usb ?
3,693件の閲覧回数
gusarambula
Hello Ahmedtolba,
There is not a specific USB example that receives a stream, my apologies.
Gustavo
3,687件の閲覧回数
ahmedtolba
Would you guide me to an MCU that supports an example with USB that receives a stream ?
3,678件の閲覧回数
gusarambula
Hello Ahmedtolba,
I’m not sure of an MCU with that specific application already set in place. The i.MX Processors run Linux and support GStreamer, which supports network sink/sources for video streams, albeit you would need to set it up.
Gustavo
3,709件の閲覧回数
gusarambula
Hello Ahmedtolba,
There is not a specific USB example that has that functionality.
However, there are a couple of USB examples as part of the i.MXRT1050 SDK, like the usb_device_video_virtual_camera example, which simulates being a camera and sending a fixed mjpeg video stream trough the USB port.
I hope that this information helps.
Gustavo
