Processor Expert Problem
3,773件の閲覧回数
GilRieke
I install codewarrior 10.6, and when I try to add an ADC component and generate the code, codewarrior has this error : Unexpected status of srcipt: Beans\ADC\ADC_LDD.chg, please contact freescale support
タグ(1)
3,300件の閲覧回数
Petr_H
We have prepared a hot-fix package for this issue. The hotfix is attached to this post.
The installation is simple, just unzip the content to the CodeWarrior installation directory.
This problem is also in Processor Expert Driver Suite 10.4 and the hofix for this product (containing this and few other fixes) can be found in this post:
Petr Hradsky
Processor Expert Support Team
5 返答(返信)
3,300件の閲覧回数
Petr_H
I'm not able to reproduce the problem. Please write more details on what CPU you are using and what settings you do in the ADC_LDD component. Zipped project would be the best.
Petr Hradsky
3,300件の閲覧回数
GilRieke
3,300件の閲覧回数
Petr_H
Thank you for the project, now I'm able to reproduce the problem. I've passed it to the development team for analysis and we'll try to prepare some solution for you as soon as possible.
Petr Hradsky
3,300件の閲覧回数
Petr_H
Additional note - for now, if you don't need specifically ADC component, use the ADC_LDD component instead. The ADC is internally using ADC_LDD anyway. Generally, the 'ADC' is still available for migration from older Processor Expert platform, however on Kinetis this component is not recommended for new designs.
Petr Hradsky
3,301件の閲覧回数
Petr_H
Petr Hradsky
