PEX from CW 10.7 Project not generating in CW 11.1
1,667 次查看
rhysdrummond
I have a project originally built in CW 10.7 whose Processor Expert configuration generates ok there.
We recently upgraded to CW11.1 after a HDD failure. Everything else seems to work, but when I try to generate PEx code I get the following:
Generator: ERROR: at line 1: Error in reading driver source: ""
(on GenericSWI2C, MCULibConfig, Utility, and Wait components)
Generator: FAILURE: at line 273: Unexpected status, please contact Freescale support. (file: Drivers\sw\RTOSAdaptor\Common_RTOSAdaptor.prg)
(on Serial_LDD, ADC_LDD, SPIMaster_LDD, and WatchDog_LDD components)
It seems that anything to do with MCULibConfig has a problem, but I really have no idea what is wrong, and can't seem to be able to resolve this.
Any hints would be greatly appreciated. Thanks in advance.
1,664 次查看
rhysdrummond
Answered my own question.
I hadn't imported the MCUOnEclipse beans- a crucial part of the setup process which I missed.
Download from this page: https://sourceforge.net/projects/mcuoneclipse/files/PEx%20Components/
Then from main menu / Processor Expert - Import Component(s), select the 2 Bean files.
Happy days
1,659 次查看
ZhangJennie
so your problem has been solved. if any other question, please contact us again.
Best Regards
Jun Zhang
1,665 次查看
rhysdrummond
Happy days
