PE components list
PE components list
DK1BN
where can I find a PE components list (former beans) for the different license versions. We have a "CW Standard License"  and in the old CW 6.3 we get a license issue  on PE I2C hardware component. I think there was a list of PE components (beans) associated with the different license versions but cant find it any more.
Walter
DK1BN
Hello Vojtech,
we are still using CW 6.3 (classic IDE- for S08 controllers etc.) and I think it is the latest version .
We did not check the CW for Eclipse version for this project.
Best Regards
Walter
vfilip
Generally - the InternalI2C component is part of the "Advanced Components" category. Components from this category can be used only with "Professional suite" license in Processor Expert for CW Classic version (e.g CW V6.3).
I think you have the following options in case you want to use this component:
#1 Move the project to CW V10.3 (Eclipse)
#2 Buy "Professional Suite" license for CW V6.3
#3 Buy license for InternalI2C component for CW V6.3
#4 Generated code for InternalI2C in Eclipse version and import it into Classic as e.g. user module.
best regards
Vojtech Filip
Processor Expert Support Team
DK1BN
Hello Vojtech,
thanks for info. I used the an evaluation version for the project and
much to my surprise detected that it was not included with the "standard
license". So my former question was where can I find a list which PE
components are included with the "standard license". I did see such a
list years ago but could not find it anymore.
Of course the problem will be solved with the Eclipse version.
Walter
Am 11.02.2013 15:55, schrieb Vojtech Filip:
Freescale Community <https://community.freescale.com/index.jspa>
PE components list
created by Vojtech Filip <https://community.freescale.com/people/VF>
in /Processor Expert Software/ - View the full discussion
<https://community.freescale.com/message/315338#315338>
vfilip
you can check README.txt of your installation:
{CW}/ProcessorExpert
best regards
Vojtech Filip
vfilip
could you please specify what version of CW do you use? However in CW for Eclipse there should be available all components except some special components like Nano SSH and some special components for 56800.
best regards
Vojtech Filip
