PE component for I2S on Kinetis?
2,901件の閲覧回数
DustyStew
Does anyone know of PE component for I2S that will run on Kinetis?
If not, what's the shortest path to getting I2S up, for a bareboard application (using PE for all other peripherals)?
3 返答(返信)
2,535件の閲覧回数
vfilip
there are available SSI_LDD and I2S_init components. If you are not sure which component to select for requested device I would recommend to open "Processsor" view and right click on a peripheral - the pop-up menu will provide corresponding components.
best regards
Vojtech Filip
Processor Expert Support Team
2,535件の閲覧回数
DustyStew
Thanks...I missed that. I thought SAI was the generic name for the I2S peripheral. I am surprised though that the document refers to it as I2S. So why not call is I2S_LDD?
2,535件の閲覧回数
vfilip
I understand that it can be confusing, but we try to keep the same API across multiple peripherals in all LDD components, so it is not always the case the the peripheral name correspond to the LDD prefixed name (TimerUnit_LDD, etc.).
best regards
Vojtech Filip
