PE Code generator FAILURE
1,395 次查看
k_anandprabu
Description Resource Path Location Type
Generator: FAILURE: Unexpected status of script: Drivers\Common\SetRegBitMask.prg, please contact Freescale support. test1 SystemTimer1 Processor Expert Problem
I downloaded and installed PExDriverSuite_v10.4 hoping it will have all updated components. but I'm facing this issue.
I'm using SKEAZ128MLH4
1,367 次查看
Alexis_A
Hello @k_anandprabu,
This error seems strange, I will suggest trying for the MKE06Z128xxx4, this code generated for this MCU is compatible with the KEA. Also, I also suggest using the PE versión included in the CodeWarrior IDE.
Alexis Andalon
