MKV30F64VLF10 processor expert
daniel_cwb
Is there  a pack for implementation of processor expert for  MKV30F64VLF10?
daniel_cwb
Jennie, Tks a lot. This update works well.
ZhangJennie
Daniel,
Good to know the problem was solved. You are welcome.
Jennie Zhang
daniel_cwb
I changed to KDS3.2 and update KSDK 1.2 as below.
Then, in New Processor Expert Project appers the MKV30F64 option.
After, a select the KSDK Absolete Path, because its was necessary.
But, after project criation I get this Project Expert ERROS. Someone knows how to fix this?
ZhangJennie
Hi Daniel,
You use SDK1.3, did you install SDK1.3 update:
Please also check if you install other kinetis related update also. If all above have been installed, you should be able to use processor expert without problem
see attached video.
Jennie Zhang
daniel_cwb
I'm using KDS 3.0 , Processor Expert 3.02, SDK1.3 , and only option for KV3x family is to KV31F.
ZhangJennie
Hi Daniel,
Please use KDS3.2 instead. This version should support MKV30F64.
Jennie Zhang
