[MK10 and Processor Expert] OSC0_CR registre reset boad
2,693件の閲覧回数
loicr
I work on thé MK10 board and I havé problem
when i configure OSCO_CR register to enable external oscillator, the board reset.
(In the cpu.c file => init hardware Function)
can you help me please ?
before Try enter in low power mode, the board worked perfectly
Loïc
5 返答(返信)
2,358件の閲覧回数
ZhangJennie
Ididn't find problem when I am working with this feature,
Please check if the on board external clock design is correct. If necessary, please upload your demo project here for check.
Jennie Zhang
2,358件の閲覧回数
loicr
finaly I don't find problem. I changed board
Thank you very much
Loïc
2,358件の閲覧回数
loicr
Up ! please
best regards
2,358件の閲覧回数
ZhangJennie
This can be either HW or SW problem.
How did you configure OSCO_CR ? by pe generated code or writing code by hand?
How to reproduce your problem?
Best Regards
Jennie Zhang
2,358件の閲覧回数
loicr
I use the PE generated code
I can't reproduce this problem on the other board
best regard
