[MK10 and Processor Expert] OSC0_CR registre reset boad
2,727 次查看
loicr
I work on thé MK10 board and I havé problem
when i configure OSCO_CR register to enable external oscillator, the board reset.
(In the cpu.c file => init hardware Function)
can you help me please ?
before Try enter in low power mode, the board worked perfectly
Loïc
5 回复数
2,392 次查看
ZhangJennie
Ididn't find problem when I am working with this feature,
Please check if the on board external clock design is correct. If necessary, please upload your demo project here for check.
Jennie Zhang
2,392 次查看
loicr
finaly I don't find problem. I changed board
Thank you very much
Loïc
2,392 次查看
loicr
Up ! please
best regards
2,392 次查看
ZhangJennie
This can be either HW or SW problem.
How did you configure OSCO_CR ? by pe generated code or writing code by hand?
How to reproduce your problem?
Best Regards
Jennie Zhang
2,392 次查看
loicr
I use the PE generated code
I can't reproduce this problem on the other board
best regard
