Kinetis K60 ADC0 and ADC1 using same reference VREFH and VREFL
3,411 次查看
MarkP_
PE doesn't allow to select same reference VREFH&VREFL to ADC0 and ADC1.
Is there any reason for this, cannot find in datasheet any restriction.
~Mark
标记 (1)
2,845 次查看
ProcessorExpert
Senior Contributor III
it is necessary to allow pin sharing to enable selection of VREFH&VREFL pins in both ADC components. You can swicth on this feature using "Pin Sharing" menu command from selected pin´s pop-up menu. For more details please see enclosed screen-shot.
For more details about pin sharing please see CW´s help:
CodeWarrior for Microcontrollers V10.x > Processor Expert Manuals > Processor Expert Users Manual > Application Design > Configuring Components > Pin Sharing
best regards
Vojtech Filip
Processor Expert Support Team
2,846 次查看
ProcessorExpert
best regards
Vojtech Filip
2,845 次查看
MarkP_
Thank's,
~Mark
