Kernel panics while connecting USB serial cable
3,307 次查看
Kathan
I am working linux kernel 3.2.54, while I connect the USB serial cable the kernel panics and the system restarts. The host controller I am using for the USB is xHCI. The serial cable which I am using is from cablecreation with product id is 23a3 and vendor id is 067b.
I have added the product id and vendor id using
echo 067b 23a0 > /sys/bus/usb-serial/driver/pl2303/new_id
I am attaching the logs of kernel panic.
3,300 次查看
ZhangJennie
Hi @Kathan
What's your chip part number? Please let us know thus we can assign right engineer for this question.
Jun Zhang
3,295 次查看
Kathan
Hi @ZhangJennie ,
Thanks for your response
Below mentioned is the chip part number
LS1024ASN7JLA NXP Mindspeed
3,264 次查看
Bio_TICFSL
The kernel you are using is not supported by nxp, you will have performance with supported kernel please check it.
