How do you use FLASH_LDD on the KL25?
2,650件の閲覧回数
jonbuckman
When I run the example PE program everything works fine. Memory locations starting at 0x10000 is written. However, when I power down or restart the memory is cleared (0xff). What am I doing wrong?
タグ(1)
2,404件の閲覧回数
BlackNight
Jon,
maybe the attached slides can help you.
Erich
2,404件の閲覧回数
jonbuckman
ah, thanks. I also found that there is a .tcl that mass erases the flash when the debugger is started.
