FLEXIO I2C Read & Write Problem
2,129 次查看
Proton_Dev
Dear Community,
I am using FLEXIO I2C for one of my eeprom. I am using SDK example of FLEXIO but I am facing issue, while writing I can not write more than 13 bytes as the data over 13 bytes is just rollover(last byte repeating). Is there any kind of limitation in flexio_I2C_driver. I am also not able to read at all from the eeprom. Is there any particular register needs to be set apart from setting the masterXfer.direction. Any lead will be helpfull.
2,099 次查看
ZhangJennie
