?? Error : clock source setting is not defined
3,112 次查看
Kumeatsu
i am trying to set the clock with "PE" set the mcg to PEE using external 50mhz source clock, but i am totally new in this and i have no idea about where i made a mistake!
!! please help me out !!
any help will be appreciated
2,957 次查看
ProcessorExpert
Senior Contributor III
Please find find the attached screen-shot (incl. project) describing how to avoid the error reported in the Screenshot from 2012-05-23 18:50:19.png in your original post.
I will also pass this issue to developers that the error message should be improved to be more clear.
best regards
Vojtech Filip
Processor Expert Support Team
2,957 次查看
ProcessorExpert
could you please post here the ProcessorExpert.pe file in order to reproduce it. Please do not forgett to close the project before sending the file.
best regards
Vojtech Filip
2,957 次查看
Kumeatsu
here there are,I change the extension of the name so it can be post
2,958 次查看
ProcessorExpert
best regards
Vojtech Filip
