Creatic static nodes in Yocto Zeus for i.MX8MM
1,852 次查看
shubham_sharmaa
Linux Fast Boot on i.MX6 Sabresd Board - NXP Community
I the above article. it is mentioned that
"Notice: Kernel configuration remove NETWORK support, it includes Unix Domain Socket, the udev mechanism need it, so this kernel configuration can't support rootfs udev dynamic /dev/ nodes and all /dev/ nodes must be created before boot up at rootfs"
I want to know how to create static /dev/ nodes before boot up without udev. We are usnig Yocto Zeus for i.MX8MM
@haidong_zheng        iMX8MMINI
4 回复数
1,772 次查看
Dhruvit
Hi @shubham_sharmaa,
I hope you are doing well.
static device nodes can be created using the mknod command.
In yocto, one can add the mknod command to create a static node in the custom bitbake recipe's do_install() section.
Thanks & Regards,
Dhruvit Vasavada
1,842 次查看
haidong_zheng
Hi @shubham_sharmaa :
Sorry, this is a very old article, please do it by yourselfves.
1,839 次查看
shubham_sharmaa
@haidong_zheng  Can you please give a direction how to proceed with it?
1,834 次查看
haidong_zheng
I don't support it now, sorry for that.
