Coldfire-Lite together with Processor Expert
4,287 次查看
Steamy
I'm running successfully the Coldfire-Lite application
and now want to add some hardware I/Os etc.
by using the Processor Expert------
4,056 次查看
ProcessorExpert
Senior Contributor III
could you please write some details about your use case ? Do you wan to use the ColdFire Lite for web server and and Processor Expert for some input-output?
Would it be a possibility for you to use MQX with Processor Expert instead?
best regards
Petr Hradsky
Processor Expert Support Team
4,056 次查看
Steamy
From Service I got this answer:
"Add processor expert to ColdFire_Lite is very, very complicated."
4,057 次查看
ProcessorExpert
best regards
Petr Hradsky
