Build failed while compiling chromium-ozone-wayland
892件の閲覧回数
Dharmik_Vaghasana
I am trying to compile chromium-ozone-wayland on Yocto for IMX8MP board, but the compilation fails with the error:
| DEBUG: Python function extend_recipe_sysroot finished
| DEBUG: Executing shell function do_configure
| ERROR at //.gn:150:5: Assignment had no effect.
| build_dotfile_settings.exec_script_allowlist +
| You set the variable "exec_script_allowlist" here and it was unused before it went
| out of scope.
| WARNING: exit code 1 from a shell command.
ERROR: Task (/home/admin/Dharmik/IMX8M-Plus/sources/meta-browser/meta-chromium/recipes-browser/chromium/chromium-ozone-wayland_138.0.7204.157.bb:do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2814 tasks of which 2800 didn't need to be rerun and 1 failed.
I have added CORE_IMAGE_EXTRA_INSTALL += "chromium-ozone-wayland" in conf/local.conf
Below is my yocto configuration,
Build Configuration:
BB_VERSION = "2.16.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "aarch64-poky-linux"
MACHINE = "imx8mp-lpddr4-evk"
DISTRO = "fsl-imx-wayland"
DISTRO_VERSION = "6.18-whinlatter"
TUNE_FEATURES = "aarch64 armv8a crc crypto"
Dharmik
3 返答(返信)
884件の閲覧回数
dianapredescu
Hi Dharmik,
Can you try adding to local.conf one more thing besides chromium package?
PREFERRED_VERSION_gn-native = "0+git"
Let me know if the issue still persists.
Diana
882件の閲覧回数
Dharmik_Vaghasana
After adding PREFERRED_VERSION_gn-native = "0+git" changes I am getting below error,
| ERROR at //build/config/linux/dri/BUILD.gn:11:20: Script returned non-zero exit code.
| dri_driver_dir = exec_script(pkg_config_script,
| Current dir: /home/admin/Dharmik/IMX8M-Plus/build-imx8mp/tmp/work/armv8a-mx8mp-poky-linux/chromium-ozone-wayland/138.0.7204.157/sources/chromium-138.0.7204.157/out/Release/
| Command: python3 /home/admin/Dharmik/IMX8M-Plus/build-imx8mp/tmp/work/armv8a-mx8mp-poky-linux/chromium-ozone-wayland/138.0.7204.157/sources/chromium-138.0.7204.157/build/config/linux/pkg-config.py --dridriverdir dri
| Returned 1 and printed out:
| Error from pkg-config.
| stderr:
| Package dri was not found in the pkg-config search path.
| Perhaps you should add the directory containing `dri.pc'
| to the PKG_CONFIG_PATH environment variable
| No package 'dri' found
| See //media/gpu/sandbox/BUILD.gn:31:18: which caused the file to be included.
| configs += [ "//build/config/linux/dri" ]
Dharmik
879件の閲覧回数
dianapredescu
I've seen this error in the past Chromium versions, and what worked for me in that build situation was a change in this file:
\tmp\work\armv8a-mx8-poky-linux\chromium-ozone-wayland\117.0.5938.132\chromium-117.0.5938.132\media\gpu\sandbox\BUILD.gn
if (current_cpu != "s390x" && current_cpu != "ppc64" && is_linux && ozone_platform_x11 &&
      !is_castos) {
    # For DRI_DRIVER_DIR.
Adding "&& ozone_platform_x11 " to the platform list at the bottom of this files fixed the issue.
Could you check whether Chromium v138 has already ozone_platform_x11 added?
Diana
%3CLINGO-SUB%20id%3D%22lingo-sub-2385802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Echromium-ozone-wayland%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E4%B8%AD%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EYocto%E3%81%A7IMX8MP%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%ABchromium-ozone-wayland%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20Python%20%E9%96%A2%E6%95%B0%20extend_recipe_sysroot%20%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%7C%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%E9%96%A2%E6%95%B0%20do_configure%20%E3%82%92%E5%AE%9F%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3E%7C%20%E3%82%A8%E3%83%A9%E3%83%BC%20%2F%2F.gn%3A150%3A5%3A%20%E4%BB%A3%E5%85%A5%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%7C%20build_dotfile_settings.exec_script_allowlist%20%2B%3CBR%20%2F%3E%20%7C%20%5E---------------------------------------------%3CBR%20%2F%3E%E3%81%93%E3%81%93%E3%81%A7%E5%A4%89%E6%95%B0%E3%80%8Cexec_script_allowlist%E3%80%8D%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BB%A5%E5%89%8D%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E5%AF%BE%E8%B1%A1%E5%A4%96%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8B%E3%82%89%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%201%20%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF(%2Fhome%2Fadmin%2FDharmik%2FIMX8M-Plus%2Fsources%2Fmeta-browser%2Fmeta-chromium%2Frecipes-browser%2Fchromium%2Fchromium-ozone-wayland_138.0.7204.157.bb%3Ado_configure)%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%EF%BC%9A2814%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E8%A9%A6%E8%A1%8C%E3%81%95%E3%82%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A12800%E5%80%8B%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%AE%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%E5%80%8B%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Econf%2Flocal.conf%20%E3%81%AB%20CORE_IMAGE_EXTRA_INSTALL%20%2B%3D%20%22chromium-ozone-wayland%22%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E7%A7%81%E3%81%AE%E3%83%A8%E3%82%AF%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%3A%3CBR%20%2F%3E%20BB_VERSION%20%3D%20%222.16.0%22%3CBR%20%2F%3EBUILD_SYS%20%3D%20%E3%80%8Cx86_64-linux%E3%80%8D%3CBR%20%2F%3ENATIVELSBSTRING%20%3D%20%E3%80%8C%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%AB%E3%80%8D%3CBR%20%2F%3ETARGET_SYS%20%3D%20%22aarch64-poky-linux%22%3CBR%20%2F%3EMACHINE%20%3D%20%22imx8mp-lpddr4-evk%22%3CBR%20%2F%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%20%22fsl-imx-wayland%22%3CBR%20%2F%3EDISTRO_VERSION%20%3D%20%E3%80%8C6.18-whinlatter%E3%80%8D%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22aarch64%20armv8a%20crc%20crypto%22%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%80%E3%83%AB%E3%83%9F%E3%83%83%E3%82%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2385813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Build%20failed%20while%20compiling%20chromium-ozone-wayland%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%81%8E%E5%8E%BB%E3%81%AEChromium%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%82%82%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%A6%8B%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E7%8A%B6%E6%B3%81%E3%81%A7%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%AF%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%223%22%3E%5Ctmp%5Cwork%5Carmv8a-mx8-poky-linux%5Cchromium-ozone-wayland%5C117.0.5938.132%5Cchromium-117.0.5938.132%5Cmedia%5Cgpu%5Csandbox%5CBUILD.gn%3C%2FFONT%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eif%20(current_cpu%20!%3D%20%22s390x%22%20%26amp%3B%26amp%3B%20current_cpu%20!%3D%20%22ppc64%22%20%26amp%3B%26amp%3B%20is_linux%20%26amp%3B%26amp%3B%20ozone_platform_x11%20%26amp%3B%26amp%3B%0A%20%20%20%20%20%20!is_castos)%20%7B%0A%20%20%20%20%23%20For%20DRI_DRIVER_DIR.%0A%20%20%20%20configs%20%2B%3D%20%5B%20%22%2F%2Fbuild%2Fconfig%2Flinux%2Fdri%22%20%5D%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E4%B8%8B%E9%83%A8%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E3%80%8C%3CEM%3E%3CSTRONG%3E%26amp%3B%26amp%3B%20ozone_platform_x11%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FEM%3E%E3%80%8D%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EChromium%20v138%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8Bozone_platform_x11%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%80%E3%82%A4%E3%82%A2%E3%83%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2385812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Build%20failed%20while%20compiling%20chromium-ozone-wayland%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EPREFERRED_VERSION_gn-native%20%3D%20%220%2Bgit%22%20%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7CDEBUG%3A%20Python%E9%96%A2%E6%95%B0extend_recipe_sysroot%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%7CDEBUG%3A%E3%82%B7%E3%82%A7%E3%83%AB%E9%96%A2%E6%95%B0%E3%81%AE%E5%AE%9F%E8%A1%8Cdo_configure%3CBR%20%2F%3E%7C%2F%2Fbuild%2Fconfig%2Flinux%2Fdri%2FBUILD.gn%3A11%3A20%E3%81%A7%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%8C%E3%82%BC%E3%83%AD%E3%81%A7%E3%81%AA%E3%81%84%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%7Cdri_driver_dir%20%3D%20exec_script(pkg_config_script%2C%3CBR%20%2F%3E%7C%5E----------%3CBR%20%2F%3E%7C%E7%8F%BE%E5%9C%A8%E3%81%AE%E7%B7%A8%E9%9B%86%E5%90%8D%3A%20%2Fhome%2Fadmin%2FDharmik%2FIMX8M-Plus%2Fbuild-imx8mp%2Ftmp%2Fwork%2Farmv8a-mx8mp-poky-linux%2Fchromium-ozone-wayland%2F138.0.7204.157%2Fsources%2Fchromium-138.0.7204.157%2Fout%2FRelease%2F%3CBR%20%2F%3E%7C%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20python3%20%2Fhome%2Fadmin%2FDharmik%2FIMX8M-Plus%2Fbuild-imx8mp%2Ftmp%2Fwork%2Farmv8a-mx8mp-poky-linux%2Fchromium-ozone-wayland%2F138.0.7204.157%2Fsources%2Fchromium-138.0.7204.157%2Fbuild%2Fconfig%2Flinux%2Fpkg-config.py%20--dridriverdir%20dri%3CBR%20%2F%3E%7C1%E6%9E%9A%E8%BF%94%E5%93%81%E3%81%97%E3%81%A6%E5%8D%B0%E5%88%B7%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%7C%3CBR%20%2F%3E%7Cpkg-config%E3%81%8B%E3%82%89%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%7C%3CBR%20%2F%3E%7C%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%AB%3A%3CBR%20%2F%3E%7C%3CBR%20%2F%3E%7Cpkg-config%E3%81%AE%E6%A4%9C%E7%B4%A2%E3%83%91%E3%82%B9%E3%81%AB%E3%81%AFdri%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%7C%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%8Cdri.pc%E3%80%8D%E3%82%92%E5%90%AB%E3%82%80%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%81%BB%E3%81%86%E3%81%8C%E3%81%84%E3%81%84%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%7CPKG_CONFIG_PATH%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AB%3CBR%20%2F%3E%7C%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E3%80%8C%E3%83%89%E3%83%AA%E3%80%8D%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%7C%3CBR%20%2F%3E%7C%2F%2Fmedia%2Fgpu%2Fsandbox%2FBUILD.gn%3A31%3A18%3A%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%9F%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%7Cconfigs%20%2B%3D%20%5B%20%22%2F%2Fbuild%2Fconfig%2Flinux%2Fdri%22%20%5D%3CBR%20%2F%3E%7C%5E-------------------------%3CBR%20%2F%3E%7C%E8%AD%A6%E5%91%8A%3A%E3%82%B7%E3%82%A7%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8B%E3%82%89%E3%82%B3%E3%83%BC%E3%83%891%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%80%E3%83%AB%E3%83%9F%E3%83%83%E3%82%AF%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2385806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Build%20failed%20while%20compiling%20chromium-ozone-wayland%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CSPAN%3E%E3%80%81%E3%83%80%E3%83%AB%E3%83%9F%E3%83%83%E3%82%AF%E3%81%95%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSTRONG%3Elocal.conf%3C%2FSTRONG%3E%E3%81%ABchromium%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E4%BB%A5%E5%A4%96%E3%81%AB%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3EPREFERRED_VERSION_gn-native%20%3D%20%220%2Bgit%22%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3E%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%80%E3%82%A4%E3%82%A2%E3%83%8A%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
