Bug ADC Processor Expert: Bad casting and non initialisation of variable
2,144 次查看
matthieu_favre-
We discovered that our ADC processor expert configured peripheral wasn't giving us the right conversion value.
We figured out that a non initialised 32bits variable was writen (and used thereafter) by a cast 16Bits variable. Depending of the initial state of the memory, the returned value of the ADC was wrong!!!
标记 (4)
1,992 次查看
marek_neuzil
The hot fix for KDS 2.0.0 and CW MCU 10.6.2 has been created and verified. See attached hot fix packages.
Marek Neuzil
1,992 次查看
marek_neuzil
Thank you for the reporting of this issue. Processor Expert development team have fixed source code of the driver and we are going to provide a hot fix for this issue. I will post the hot fix here.
Marek Neuzil
