PT2001 Vboost shortcut questions
Fast
PT2001SWUG Rev 3.0 says "Note that in order to use the async or sync mode, the low-side use for DCDC has to be set as shortcut 2 (ex: dfsct undef ls7 undef). "
Yet no examples of firmware use that line of code. Is statement true, is it another hangover from PT2000?
Fast
Yes close. Can you link these conversations. I do not want to "fall between two stools", I am surprised that this is a new question, considering the age of the MC33816. Please pick up the "baton", RafaR. Sorry for the English idioms.
guoweisun
Hi Fast
Could you please give more explain about your issue/questions? That's difficult for understanding!
Fast
Good morning guoweisun,
Please see the conversation with RafaR.
I am looking for guidance on DCDC code using the PWM mode ( AKA manual mode) , all microcode. That is not using the resonant mode since PT2001 cannot support on LS7 as no Vds sensing. I am led to believe that in PWM mode, and with Vboost capacitor grounded, so Vboost not effected by Iboost phase at injector which disturbs current control.
guoweisun
Hi Fast
Since Rafael Rojas supported to you before please directly contact with him for continuous support.
Rafael is my colleague I think he will help you continuously.
Thanks!
Fast
Fast
See Vboost using PWM (manual) NOT hysteretic. Set LS7 Slewrates to max, very clean waveforms at 100kHz
%3CLINGO-SUB%20id%3D%22lingo-sub-2024979%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPT2001%20Vboost%20shortcut%20questions%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2024979%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPT2001SWUG%20Rev%203.0%20says%20%22Note%20that%20in%20order%20to%20use%20the%20async%20or%20sync%20mode%2C%20the%20low-side%20use%20for%20DCDC%20has%20to%20be%26nbsp%3Bset%20as%20shortcut%202%20(ex%3A%20dfsct%20undef%20ls7%20undef).%20%22%3C%2FP%3E%3CP%3EYet%20no%20examples%20of%20firmware%20use%20that%20line%20of%20code.%20Is%20statement%20true%2C%20is%20it%20another%20hangover%20from%20PT2000%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2024979%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESolenoid%20Controller%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2029868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PT2001%20Vboost%20shortcut%20questions%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2029868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESee%20Vboost%20using%20PWM%20(manual)%20NOT%20hysteretic.%20Set%20LS7%20Slewrates%20to%20max%2C%20very%20clean%20waveforms%20at%20100kHz%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2027490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PT2001%20Vboost%20shortcut%20questions%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2027490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EYes%20close.%20Can%20you%20link%20these%20conversations.%20I%20do%20not%20want%20to%20%22fall%20between%20two%20stools%22%2C%20I%20am%20surprised%20that%20this%20is%20a%20new%20question%2C%20considering%20the%20age%20of%20the%20MC33816.%20Please%20pick%20up%20the%20%22baton%22%2C%20RafaR.%20Sorry%20for%20the%20English%20idioms.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2027133%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PT2001%20Vboost%20shortcut%20questions%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2027133%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Fast%3C%2FP%3E%0A%3CP%3ESince%20Rafael%20Rojas%20supported%20to%20you%20before%20please%20directly%20contact%20with%20him%20for%26nbsp%3Bcontinuous%20support.%3C%2FP%3E%0A%3CP%3ERafael%20is%20my%20colleague%20I%20think%20he%20will%20help%20you%26nbsp%3Bcontinuously.%3C%2FP%3E%0A%3CP%3EThanks!%3C%2FP%3E%0A%3CH1%20class%3D%22cw-primaryText-430%22%20title%3D%22Rafael%20Rojas%22%20data-log-name%3D%22DisplayName%22%20id%3D%22toc-hId-1241416141%22%20id%3D%22toc-hId-1300406321%22%3E%26nbsp%3B%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2026683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PT2001%20Vboost%20shortcut%20questions%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2026683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGood%20morning%26nbsp%3Bguoweisun%2C%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EPlease%20see%20the%20conversation%20with%20RafaR.%3C%2FP%3E%3CP%3EI%20am%20looking%20for%20guidance%20on%20DCDC%20code%20using%20the%20PWM%20mode%20(%20AKA%20manual%20mode)%20%2C%20all%20microcode.%20That%20is%20not%20using%20the%20resonant%20mode%20since%20PT2001%20cannot%20support%20on%20LS7%20as%20no%20Vds%20sensing.%20I%20am%20led%20to%20believe%20that%20in%20PWM%20mode%2C%20and%20with%20Vboost%20capacitor%20grounded%2C%20so%20Vboost%20not%20effected%20by%20Iboost%20phase%20at%20injector%20which%20disturbs%20current%20control.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2026444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PT2001%20Vboost%20shortcut%20questions%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2026444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Fast%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20give%20more%20explain%20about%20your%20issue%2Fquestions%3F%20That's%20difficult%20for%20understanding!%3C%2FP%3E%3C%2FLINGO-BODY%3E
