Custom Actuator
Custom Actuator
2,600 次查看
igor_lumpus
Evaluation of the PT2000 Simulator.
We have just started looking into the PT2000 Simulator and it seems to work as expected when it comes to stepping through the code.
Our problem is that the actuator we are running does not match the ideal R/L loads in the existing templates.
There is an option to use a Custom Actuator which can be specified either as a static table (FeedBack Source = Form) or as a C# file (FeedBack Source = External)
We need to use the C# file method but the documentation lacks on what is what.
In particular is it the list of all actuator currents given in the arguments
   int[] oldCurrentValues
Where is it configured which actuator is on which index in the list?
标记 (2)
2,561 次查看
petervlna
I have check for the SW internally and I cannot find any records of it.
Looks like author didn't release it with AN at all.
Furthermore, I was not able to contact author as he is no longer in company.
regards,
Peter
