Cannot find PT2001 SpiGen configuration file
3,504件の閲覧回数
rdrosescu
I can't find PT2001 SpiGen configuration file to be able to properly configure Spi Generator Software as specified in FRDMPT2001EVM Evaluation Board - User Guide -see page 14/25 .(https://www.nxp.com/docs/en/user-guide/KTFRDMPT2001EVMUG.pdf) .
I Quote: “Browse for the SPIG configuration file downloaded from the tool summary page
(see Section 6.1.1 "Installing SPIGen on the host PC"). Select the configuration file and click Open. SPIGen creates a SPI command generator configured specifically for the FRDMPT2001EVM board.”
I guess it should be a file named KITPT2001AESW-EVBS.
Can the PT2000 configuration file (KITPT2000AESW-EVBS) for PT2001 be used?
Thanks!
Radu
3,473件の閲覧回数
rdrosescu
As I wrote in a previous email everything has been resolved and the case can be closed. I don't know why the email was returned, the address being noreplay. Maybe this time it will work. Thanks again.
Radu
3,474件の閲覧回数
rdrosescu
Radu
3,491件の閲覧回数
guoweisun
The file for the PT2000 should work.Please try it!
